Low beam issues
Old Jan 19, 2021 | 10:37 AM
0thompta's Avatar
0thompta
Default Low beam issues
well I’m about 90% stupid. I didn’t realize the stalk on the steering column contained the high beam switch! It was so worn down there is no longer any markings. I assumed pulling the **** out for the headlights the first click was for low beams! Oh my god
Hey guys, I’ve done some searching and still can’t seem to figure out why my low beams don’t work or retract the headlights. I replaced the switch, checked 3-4 grounds around there, and haven’t noticed anything out of the ordinary.
I notice that sometimes my turn signals don’t blink but simply stay on. Could a bad turn signal relay or even the relays near the front left headlight cause these issues? Should I clean up the main harness connector or is this just harmless dielectric grease? I also tested the low beams on the bulbs independently and they work fine.
