Polishing Aluminum....
Old Dec 9, 2002 | 12:08 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Polishing Aluminum....
I have started polishing my plenum, again, I have knocked almost everything down with a metal file, and 80 grit sand paper, and plan on going down to 1500 wet sanding, and then polishing it. For those of you that have done it what grit paper did you use before polishing? Should I go down to 2200?
TIA
-NO91
Old Dec 9, 2002 | 01:40 PM
fullboogie
Default Re: Polishing Aluminum.... (No Ordinary 91)
When I polished the intake on my Ford, I got down to 1200 before going to the polishing wheel. Seemed to work fine for me.
Old Dec 9, 2002 | 02:47 PM
MIke350's Avatar
MIke350
Default Re: Polishing Aluminum.... (fullboogie)
when i did my wheels i went to 2000, dont think you really need to go that far but the 2000 paper was easy to find
Old Dec 9, 2002 | 03:50 PM
bogus's Avatar
bogus
when your all done, make sure you put some kinda protectant on it.
the aluminum will fade and you will have to keep polishing it...
Old Dec 9, 2002 | 03:54 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Default Re: Polishing Aluminum.... (bogus)
The best protectant I found is just having it chromed! I found out the hard way that polished alum is hard to keep that way. :seeya
Old Dec 10, 2002 | 04:51 AM
87Beast's Avatar
87Beast
Default Re: Polishing Aluminum.... (MJT383NO2)
Used 1200 and topuched up with 2000.
Old Dec 10, 2002 | 08:36 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
The following works well for me.
Use the BUSCH'S alum. polishing products....When done with the Bushes Alum. polish finish off with Bushes Alum. wax and sealer. I bought these products from the Ecklers catalog.....
And am proof on how well they work, and hold the polished look.
good luck
tony
:flag :flag :cool:
To Polishing Aluminum....
