'89 C4 spark plug wire flail...
Old Jan 20, 2021 | 03:59 PM
NavAir's Avatar
NavAir
Default '89 C4 spark plug wire flail...
Maybe just venting a bit. I finally decided to replace the original (that's right - 32 year-old) spark plug wires on my C4. I'm quite mechanically adept, so I estimated about an hour for the job. Well, 4 hours later and a unit of blood lighter, I finally got the job (mostly) done. I expected to break some of the 32 year-old plastic wire looms (and did), but I bought some new ones to have in reserve. What I wasn't prepared for was the lack of clearance in several spots, especially for the 3 wires that run under and behind the distributor, and around the left rear of the engine. The car is not modified in any way. I had to use a piece of hangar wire to fish them through.
Luckily, I got them all on the correct terminals, and she started up fine. But the whole evolution brought to mind the old adage: "If it ain't broke, don't fix it"...
Old Jan 20, 2021 | 08:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed, spark plugs/wires are not a trivial (time wise) job.
