WIRING QUESTION
Old Dec 9, 2002 | 02:46 PM
Secrt007Agt's Avatar
Secrt007Agt
Default WIRING QUESTION
ON MY 93 C-4, I RECENTLY REMOVED THE UPPER RADIATOR TANK TO PAINT IT. THIS IS THE TANK UNDER THE HOOD, IN FRONT OF THE PASSENGER SIDE, OPPOSITE FROM THE COMPUTER. WHEN I REMOVED IT, I DID NOT REMEMBER TO NOTE THE WIRE CONFIGURATION UNDER THE TANK. I AM REFERING TO THE 3 WAY SPLIT CONNECTION LOCATED UNDER THE UPPER TANK. WELL, NOW I HAVE DISCOVERED, AFTER RE-INSTALLING THE TANK, A UNUSED WIRE WITH A BLUE CONNECTER, MAKING A 4TH UNUSED CONNECTION AT THE NORMAL 3 WAY CONNECTER MENTIONED ABOVE. I HAVE CHECKED A COUPLE OF OTHER C-4'S, BUT THEY ONLY HAVE A 3 WAY WIRE SPLIT, NOT A 4TH, SO I AM AT A LOSS. I DID NOTE A WIRE WITH A "BLUE CONNECTER" ON A C-4, (PART OF A 3 WAY CONNECTER) BUT IT WAS CONNECTED TO A WIRE IN THE LOWER COMPARTMENT. ONE OF MY 4 WIRES IS CONNECTED DOWN IN THAT LOWER AREA, SO I'M SURE THAT WIRE IS HOOKED UP PROPERLY. EVERYTHING APPEARS TO BE WORKING & NO MODIFICATIONS WERE MADE BY THE OWNER BEFORE ME. COULD THIS 4TH CONNECTER BE A "TEST" WIRE FOR SOMETHING? THANKS FOR ANY HELP :nopity
