AC bracket broken
Old Jan 23, 2021 | 10:11 AM
MarkB85vette's Avatar
MarkB85vette
Default AC bracket broken
Hello team,
I am in the process of replacing my water pump which has failed. In doing so I am going to install a new AC compressor to replace the old one which works poorly. As this process has unfolded I have found that the upper part of the AC bracket is broken at the forward connection point. As I have looked for replacements, the parts I have found online look different. Supposedly they fit but the lower section of the bracket that mounts to the water pump is missing on the replacement item. Any thoughts on this would be great. Thanks.
Mark.
Old Jan 23, 2021 | 04:28 PM
BillDurant's Avatar
BillDurant
we just did the same thing here, we replaced the water pump and valve cover gaskets so we moved a bunch of stuff out of the way
our compressor bracket has several fractures in it, one very bad so I took it to a local welder and he put it back together
should be nice and secure now and belt seems nice and tight
couldn't find one exact on line nor at a local junk yard
mine is an 89
Old Jan 23, 2021 | 04:51 PM
MarkB85vette
Kinda thought that might be a solution. Thanks for the update!
Old Jan 23, 2021 | 08:21 PM
DWAVette's Avatar
DWAVette
Default Bracket
I am about to pull all that off myself. Is it possible it was broken from being taken apart or just fatigue? Trying to figure what to expect.
Old Jan 23, 2021 | 08:32 PM
flyboyslc1's Avatar
flyboyslc1
Default Make sure all your braces are in place
Seems like over the years a lot of alternator and ac compressor braces get tossed and not used. This causes bracket failure over time. I did a video showing where they all go. I was able to find most of the braces on eBay but did fab up one of them myself
Old Jan 23, 2021 | 10:36 PM
MarkB85vette
Thanks, this is helpful. I omly found the AC bracket broken, all others look good so far. I may be looking at welding rather than replacement.
To AC bracket broken
