89 rebuild
Old Jan 25, 2021 | 06:16 PM
Growth 3's Avatar
Growth 3
Default 89 rebuild
Getting ready to pull my motor out for a rebuild. I noticed there is a small water line that comes out of the back of the intake manifold and goes to the heater hose. First, what is the purpose of it an second can I just plug the intake off and not use it. Thanks
Old Jan 26, 2021 | 01:31 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe that line is necessary for proper coolant flow through the manifold.
Had it burst on my prior '88; you might might want to install a new one.
Old Jan 26, 2021 | 05:01 PM
Siveck's Avatar
Siveck
Steam vent. I think it can be eliminated if you use the right configuration of intake gaskets. However, it was installed to help with eliminating air pockets if I recall correctly.
Old Jan 27, 2021 | 11:08 PM
ajp01's Avatar
ajp01
Steam vent is right. The front coolant passages on the '89 heads / intake manifold are open to the thermostat and radiator outlet flow. The back water ports on the heads are closed off with the gasket, except for a 1/8" (approx.) hole in the gasket itself that allows pressurized steam and a bit of water to flow through that passage, and it exhausts the steam/water into that 5/16" metal pipe and small hose back to the main heater hose. I think the manifold is configured specifically for those passages on the '89 because I've seen the TPI Camaro/Firebird intake manifolds and they don't use that fitting and steam pipe. They must handle those air pockets differently near the back of the heads.
Preserve your original parts and clean them, because those small 5/16" pipe and fittings are discontinued from GM last time I checked. May find them through a salvage yard though.
Old Jan 29, 2021 | 04:55 PM
InfomanSS's Avatar
InfomanSS
Be sure to get the correct intake gaskets. The Camaro/Firebird TPI's didn't have it and use different gaskets. Top is the Corvette and bottom is F-body.
Old Jan 29, 2021 | 07:22 PM
Growth 3's Avatar
Growth 3
Thanks for all the info guys. I have the original metal tubes and am trying to clean them up to reuse. Was thinking about just trying to use some 5/16 brake line but with that flare on the original tubes I don't know how to make it.
Old Jan 29, 2021 | 11:15 PM
ajp01's Avatar
ajp01
Yeah - the flare on one side is just a normal, simple flare toward the intake manifold fitting. But that other one that the hose itself connects to is an internal ridge flare in two places to help lock the hose clamp, and that I don't know how to do either. So I've kept mine and am just cleaning it up from rust, etc... I'm also planning on using some thread sealing compound near the flare fitting and the threads because I've seen those leak if they are dry.
Old Jan 30, 2021 | 09:49 PM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
If you look up a tube beading tool you will find what you need to make the "bead" on the opposite end. Comes in quite handy when needed to prevent lines from slipping off
To 89 rebuild
