Common Oil Leaks on 96 LT1
Old Dec 10, 2002 | 01:07 PM
T'sVette's Avatar
T'sVette
Cruising
Default Common Oil Leaks on 96 LT1
I recently replaced the intake gaskets that were seeping oil at the ends and now I still have another oil leak from other areas. :( Leaves a nickel size spot overnight. Leaky cars really **** me off.
My intent is to get the car in the air this weekend and take a close look.
What are the most common areas for oil leaks on an LT1?
Thanks in advance for you help.
Dan
Old Dec 10, 2002 | 01:13 PM
bogus's Avatar
bogus
Default Re: Common Oil Leaks on 96 LT1 (T'sVette)
You found the #1 leak.
the rest...
oil drain plug
oil pressure sender
valve cover
front main
rear main
oil filter
oil pan
However, it takes lotsa miles before the mains become a problem... same with the oil pan...
the best way to find a leak is to clean a part of the parking surface. then, apply some duck tape to the area after you park the car.... then you can triangulate where the leaks are. I like tape on the rear of the front tires, and centered in the front of the car. you can also add tape to the front of the front tires... this is all taped to the parking surface.
Old Dec 10, 2002 | 04:27 PM
T'sVette's Avatar
T'sVette
Cruising
Thanks Andy,
I will check it out this weekend. I will also check the intake again, as I did a search on the forum and found a couple of guys had sealing problems if they didn't use the ultra blue silicone. I used the black silicone that came with the fel-pro gasket set.
Old Dec 10, 2002 | 04:32 PM
96GS#007's Avatar
96GS#007
On a '96, if it's from the front, also check..
The waterpump driveshaft seal
Optispark seal in the timing cover
Crankshaft seal in the timing cover
Old Dec 10, 2002 | 09:08 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Check the oil filter adaptor. :yesnod:
Old Dec 10, 2002 | 09:11 PM
Goody's Avatar
Goody
Default Re: Common Oil Leaks on 96 LT1 (mackeyred96)
Mine leaks a bit from the oil filter adapter. Will fix it one of these days. :rolleyes:
Old Dec 11, 2002 | 10:31 PM
T'sVette's Avatar
T'sVette
Cruising
Default Re: Common Oil Leaks on 96 LT1 (Goody)
Thanks Guys.
I will check the oil filter adapter this weekend and let ya know. :yesnod:
I double checked the intake last night and I didn't find any leaks, so there is a good chance it is the oil filter adapter.
One thing I have found out,,,, replacing my Wife's 88 Monte SS with a 96 Vette is just as much or more upkeep. You would think 8 years and 100k miles newer would be like a new car. :crazy:
Thanks again.
Dan :D
Old Dec 12, 2002 | 12:47 AM
maduraj's Avatar
maduraj
Here's how I'm fixing my oil leaks :smash:
Old Dec 12, 2002 | 10:22 AM
lead_foot's Avatar
lead_foot
Don't forget the crank position sensor? Mines leaking. :)
To Common Oil Leaks on 96 LT1
