So I found an easy fix. I loosened the 2 rear bolts and removed the 1 that connects to the fan shroud. I put a washer under the front bracket and reinstalled the bolt and then tightened the back 2 up again. I now have clearance between the power steering cap and upper rad hose. I wish all my C4 problems were this easy to solve!
