85 Corvette smoker
Old Feb 15, 2021 | 06:56 PM
70vetteinpieces's Avatar
70vetteinpieces
Default 85 Corvette smoker
Everytime I start up my 85 Corvette is bellows out a lot of smoke. I am assuming the valve seals have hardened over time and need replaced. Have a garage up north but 1,000 miles away. Called a few shops and they just blew me off and one replied they didn't have the tools to do it. Have a small 5 gallon air compressor and could rent a valve spring compressor. Think that would work? Also thought about performance heads but read doesn't help a stock engine very much.
I am near Brookfield if anyone recommends a garage close by
Old Feb 15, 2021 | 10:11 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
5 gallon prob fine as long as it can recharge while being installed. tool is cheap.
Amazon Amazon
i used felpro intake seals on both and cork gaskets with hylomar properly applied for vc gaskets. easy job.
Old Feb 16, 2021 | 02:30 AM
cv67's Avatar
cv67
St. Jude Donor '05
Lots of shops want nothing to do with working on these, same in my area.
If they said they dont have the tool they probably werent interested to begin with.
Old Feb 16, 2021 | 08:41 AM
Phobos84's Avatar
Phobos84
It's sad because this isn't a difficult job at all. It's just time consuming. If you have the space and are willing to pick up a few extra tools then you can totally do this yourself. I think they even have a valve spring compressor at Harbour Freight. I know you can take the Harbour Freight compression tester and use it with a air chuck to hold the valves up. Also if you have a small compressor you don't need 100 psi to hold the valve up. 50 psi works great. This will help keep the compressor you have running less often during the job.
Old Feb 16, 2021 | 02:19 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
That's something I noticed myself when I first bought mine.
Turned out to be a blessing, actually, because the one bigger job I did let a shop do was the rack and I still have to go back and adjust that thing right. Steering wheel is still off and the tie rods aren't adjusted evenly, so it has a different turn radius on each side. I'll have to make those adjustments myself when the weather breaks. The moral of that story is leaving a car with a mechanic who doesnlt really want to work on it is likely gonna leave you with a half-assed job.
When I went to pick it up the owner seemed like he was peeve just to have to work on the thing. Haven't been back there since.
Old Feb 16, 2021 | 09:11 PM
70vetteinpieces
I have done a few overhead cam 4 cylinder engines and figure a v-8 wouldn't be too much different other than taking twice as long
Old Feb 16, 2021 | 10:05 PM
Beater12's Avatar
Beater12
I can't recall because it's been decades since I've seen it done but is it advisable to turn the motor over as you do each cylinder so you get the piston close to TDC? That way if you lose pressure for any reason the valve won't disappear into the cylinder?
Old Feb 17, 2021 | 05:21 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
There's no need rotate the engine if you use the compressed air method. The air in the cylinder holds the valves in place and keeps them from dropping. The only time you need to rotate the engine is when you're adjusting the valves upon completion of the seal install.
If you have the space, by all means do it yourself. It's an easy job and you'll save a lot of money.
To 85 Corvette smoker
