z51 question
Old Dec 10, 2002 | 06:13 PM
Petros89's Avatar
Petros89
Default z51 question
I am about to order new shocks and i am not sure if i have Z51 .I don't have the RPO codes or vin(the vette is in europe).Is there a way to tell if it's a z51 without the RPO?I have 13" brakes, oil cooler,power steering cooler 6 speed ZF.Can you tell by these options if it is a Z51?Thanks for any info
Old Dec 10, 2002 | 06:41 PM
Storz's Avatar
Storz
Default Re: z51 question (Petros89)
z51 has 2 to 2.25 turns lock to lock Z52 and base suspension has 2.75 tuns lock to lock. also I belive the front air dam spoiler is larger on the Z51 car and if you have a radiator boost fan in front of the radiator, that came with the Z51...hope this helps
Old Dec 10, 2002 | 06:59 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I would bet you have Z51!
Old Dec 10, 2002 | 08:31 PM
Petros89's Avatar
Petros89
Default Re: z51 question (PeteL)
If i use Z51 shocks on non Z51 suspension would handling be affected?I think i will be getting the bilsteins.Any other shocks worth looking at?
Old Dec 11, 2002 | 11:14 AM
Storz's Avatar
Storz
I would think the rate of the Z51 shocks would be to high for the rest of the suspension, I am not totaly sure on this tho :confused:
To z51 question
