Grand Sport vs Z07 differences
Thanks.
Grand Sport (RPO Z16) was basically an appearance package except for 1 important feature. Grand Sports were all 6-speed manuals and thus came with the more powerful LT4 engine and slightly wider rear tires.Otherwise it's special paint, stripes and different style wheels.
Z07 is basically a handling and suspension package.... well actually there was no Z07 option for 96 instead they reverted back to calling it Z51. The Z51 package consisted of special shocks, front and rear springs and different bushings.
One could order a 96 Grand Sport and also order the Z51 suspension option.
Note that an easy way to see all of these different options by individual year is to invest $20.00 and buy yourself a copy of Mike Antonick's "Corvette Black Book"
Front sway bar is 30mm solid steel instead of the 24mm tubular or the 26mm tubular on ZR1 cars. BIG difference in handling.
Springs are 46% stiffer than even on the ZR1.
Steering ratio is quicker than standard.
Wishbones are slightly different, again to stiffen up the handling.
The ZO7 car was designed for the track or aggressive handling as GM stated. Many people did not like the additional stiffness of the ride even in the lowest setting of FX3 shock setting due to the items mentioned above. I never could push myself to find out exactly what the extreme limits of the handling package could do. But it will out handle the GS in stock trim but is not as fast or as good an investment as the GS. But it is amazing to feel how flat the ZO7 will corner at speed and I do miss that after selling my 92.
The rear C6 GS wheels are 19x12 et59. First things first: they have 8.82" backspacing, and that's about 0.82" too much. You will be hitting things on the inside. You'll need 7/8" or 21mm spacers/adapters to push the wheels out far enough to fit on the inside edge. But if you do that, they are going to poke outside the fender edges by about 1" on the outside edges. The only way to accommodate these would be by cutting the fender arches a lot bigger and then fitting real flares (not the stick-on 96 GS silliness), or to adapt a ZR1 rear body (if that's even possible). Aside from all that, the smallest tire that is approved for 19x12 wheels is a 325/30/19, but at 26.7" in diameter it's really too tall. A tire that tall might fit without rubbing if it were a lot narrower, but in this case it's going to be sticking out of the fender arches and will tear it up any time you go over a bump. You could stretch a 305/30/19 onto that wheel, but it's not the approved fitment still doesn't really solve the poke. The bottom line is that 12" wheels really don't fit on a stock C4 unless it's a ZR1, and especially not if they are 19s.
