Spare tire light?
Old Mar 6, 2021 | 09:21 PM
Deepa's Avatar
Deepa
My 91 comes on full brightness when I open the drivers door with the round key, when I open the door, and I turn on the interior lights with the dimmer switch.
it does not come on when I pop the rear glass
It will not come on if it’s sunny outside
not sure why yours is coming on dim at times.
Old Mar 6, 2021 | 09:30 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
It's probably something dumb. I've had a couple of quirks with lights lately.
I'm gonna be under the car tomorrow anyway changing the oil and screwing around with the shifter linkage, so I might change out that socket and bulb and see if it resolves it. Actually, I definitely will. May as well, since I have the new socket.
Old Mar 6, 2021 | 09:51 PM
Natty C's Avatar
Natty C
Originally Posted by ihatebarkingdogs
When you turned the key did the interior lights come on full brightness? They should have. If they did not, I wonder if you have a bad courtesy light relay? Which has been complicating your spare tire light testing results.
I dunno, I've never really paid much attention to how bright they were. They seem normal.
That courtesy relay does click randomly open and closed once in a while, though. Which of course sets off the courtesy lights. I have the replacement relay, Just haven't messed around with it. At first I thought it was the door switches causing it, but that wasn't it. They needed replaced anyway.
Ah well. I'll figure it out. I'm glad I found the thread, though. It'll give me something else to tinker around with.
That could be it.
Old Mar 7, 2021 | 04:20 PM
Natty C's Avatar
Natty C
Not to take away from op's original question, but I repaced the bulb. No change. Replaced the socket. No change.
I'll swap out that relay whenever I get around to it and see if that sets it straight.
Old Sep 16, 2024 | 06:37 PM
OndoC4's Avatar
OndoC4
2nd Gear
Default Yes Virgina there is a tire light
Confirmed. Turns on w the interior lights. Once the bulb is replaced.
