Thermostat temperature
Old Dec 11, 2002 | 03:00 PM
corvette90's Avatar
corvette90
Default Thermostat temperature
hi..
can anybody tell me, at which temperature a stock thermostat on a 90 Corvette opens?
thank you
Old Dec 11, 2002 | 03:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Thermostat temperature (corvette90)
I believe the L98s had 195deg F stats.
Old Dec 11, 2002 | 07:45 PM
Juliet's Avatar
Juliet
Default Re: Thermostat temperature (65Z01)
That's what mine is set to - factory stock L98. The secondary fans kick on at about 120-125 deg. ~Juliet
Old Dec 11, 2002 | 09:37 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: Thermostat temperature (Juliet)
Is it 120-125 degree or 220-225 degree? I seen my big fan (the one behind the radiator) kick on at 218 degree. I have never seen the smaller fan (the one in front of the radiator) runs :confused:
and yes, the thermostat temp. is 195
[Modified by VQT88Vette, 9:41 PM 12/11/2002]
Old Dec 11, 2002 | 10:22 PM
Juliet's Avatar
Juliet
Default Re: Thermostat temperature (VQT88Vette)
Oops typo. Yeah, I meant about 220 degrees. If I'm in heavy traffic, in summer and get to my parking spot, I keep an eye on the temp gague and watch it for a bit. Sometimes it's pretty hot when I get parked. Once it hits 220 a fan kicks on and brings it back down. I usually will let it idle until it gets down to about 205 and then shut it off. I'll admit though I never actually stuck my head underneath to see if the little fan in the front was running or not. :p:
To Thermostat temperature
