ABS sensor
Old Mar 9, 2021 | 10:08 PM
jseremba's Avatar
jseremba
Default ABS sensor
Hello everyone,
I just discovered that one of the rear passenger side ABS sensor on my 89 Corvette is NFG. Does anyone know where I can buy a new one? Or a working one?
Thank you
Joe
Old Mar 11, 2021 | 09:40 PM
aklim's Avatar
aklim
New, no. Working, hard to say. I have seen some on eBay that are in worse looking shape than mine. I had managed to get all four by getting piece by piece.
Old Mar 11, 2021 | 09:47 PM
jseremba's Avatar
jseremba
Is there a way to repair the sensor?
Old Mar 11, 2021 | 09:58 PM
aklim's Avatar
aklim
Is the wire broke? If so maybe you can solder it back. If the sensor is defective, IDK how to cut it apart and weld it back. I would say that at this point, you might have to wait on one coming from eBay.
Old Mar 11, 2021 | 10:08 PM
jseremba's Avatar
jseremba
It and the wires are in tact. So what ever has failed it is inside the casing. Carid sells a ABS sensor for the front wheel. I am wondering what the difference is between the rear and front. I am going to call them tomorrow. Thank yo
Old Mar 11, 2021 | 10:39 PM
aklim's Avatar
aklim
THIS? Unavailable.
Old Mar 12, 2021 | 04:18 AM
ChumpVette's Avatar
ChumpVette
So rockauto didn't have any?
Old Mar 12, 2021 | 06:14 AM
aklim's Avatar
aklim
Nopr. Been discontinued for years
Old Mar 12, 2021 | 07:12 AM
jseremba's Avatar
jseremba
I went to RA. Actually. They don not sell many ABS sensors. I looked through a list of cars. I was wondering if that sensor is used on other GM models. I am calling Carid, Cranburry NJ today. They sell a front ABS sensor. Is there a difference. They all look a like and have the same resistance. Just wondering.
Old Mar 12, 2021 | 07:33 AM
aklim's Avatar
aklim
Why resistance?
Old Mar 12, 2021 | 07:46 AM
jseremba's Avatar
jseremba
The ABS sensor has a specific amount of OHMS like 900 to 2000 OHMS. I did not measure the sensor. A friend that was assisting me did. This weekend I am going to measure it and check for voltage fluctuation, myself.
Old Mar 12, 2021 | 07:48 AM
jseremba's Avatar
jseremba
Has anyone used any of the bluetooth apps to analyse the OBD1 cars. Thank you
Old Mar 12, 2021 | 09:26 AM
jseremba's Avatar
jseremba
Does anyone know what actually breaks? I mean it is in the wheel hub. The wires are in tact? Just wondering.
Old Mar 12, 2021 | 12:27 PM
ChumpVette's Avatar
ChumpVette
What are you wanting to analyze?
Old Mar 12, 2021 | 12:28 PM
ChumpVette's Avatar
ChumpVette
I know. You need to go back and refresh from his original thread.
Old Mar 12, 2021 | 12:41 PM
aklim's Avatar
aklim
Just wondering. I thought that on the spinning wheel AC voltage tells all?
Old Mar 12, 2021 | 01:26 PM
jseremba's Avatar
jseremba
ChumpVette,
No I used a multi meter to determine that one of the sensors is no good. I was just wondering out loud sorta. If there is an analyzer other than the KM that does the OBD 1 ABS system. And then I was trying to figure how a sensor fails. It is in the hub. Just thinking out loud. I have TunerPro RT on my laptop. I see that there are some new programs out there. Does anyone use them. And how do they work.
Thank you
Old Mar 12, 2021 | 02:27 PM
ChumpVette's Avatar
ChumpVette
ChumpVette,
Thank you
And that's what I was telling you in your other thread, no ABS data is accessed through the 86-89 ALDL. It is considered "Off-board diagnostics". In 90, everything was tied in and ABS info is accessed through the ALDL.
Old Mar 12, 2021 | 04:11 PM
jseremba's Avatar
jseremba
CumpVette,
I heard you the first time. In fact the reader my mechanic used said exactly what you said. The light just tells you something is a miss. The KM is needed to determine the problem. We used a multi meter. Thank you again
To ABS sensor
