brake fluid, dot 3 or 4?
Old Dec 11, 2002 | 07:20 PM
BAdAzZV8's Avatar
BAdAzZV8
Default brake fluid, dot 3 or 4?
I need to know what kind of fluid to use, I am not at my car right now and I need to know. Please let me know, which dot.
Help soon please
Old Dec 11, 2002 | 07:21 PM
Goody's Avatar
Goody
Default Re: brake fluid, dot 3 or 4? (BAdAzZV8)
Ford heavy duty DOT3 is considered the best by most posters I have read on here.
Old Dec 11, 2002 | 07:45 PM
c4cruiser's Avatar
c4cruiser
Default Re: brake fluid, dot 3 or 4? (Goody)
I've used the Ford HD DOT3 fluid, but now the local F*** dealer won't stock it anymore. I've changed to Castrol LMA for street use. It has a slightly higher wet boiling point than the Ford fluid, plus I can get in 1-quart containers which is just right for a complete flush.
Old Dec 11, 2002 | 08:22 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Both DOT 3 and DOT 4 will work in your car. Try to buy something fresh in a sealed metal can, not the junk sold cheap in the chain stores.
Do not buy DOT 5. DOT 5.1 will work, but you won't find any in a chain store.
ATE at your local Ricer or Euro shop would be great.
Old Dec 11, 2002 | 08:32 PM
gtsyellow's Avatar
gtsyellow
Default Re: brake fluid, dot 3 or 4? (PeteL)
motul600 is the best cheap stuff, i had a site that listed dry and wet boiling point. the lma stuff costs a bloody fortuine & i don't see why someone would spend that yearly. even racing. a couple $14 bottles of motul600 would be my choice. if you never crank up your brakes or go racing to the point your boiling fluid the $5/qt valvoline syn power is a great street choice. the differences between dot 3 and 4 aren't anything you'd care to read about, mostly has to do with minimum wet boiling point.
Old Dec 12, 2002 | 02:54 AM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: brake fluid, dot 3 or 4? (gtsyellow)
alright, well I could only find the cheap prestone dot 3. I may do a flush later, and get some better fluid in there, but for now this will have to do.
Thanks for your help guys.
To brake fluid, dot 3 or 4?
