4+3 Maintenance Question
1) On the OD pan when reinstalling I have read to just use the gasket that came with the kit and have read to just use the RTV sealer and install the pan when the sealer is still wet. Which way is the correct way.
2) Should I clean the control valve and sensor as part of the service.
3) Should I use Dexron II or III fluid.
4) Should I do the radiator flush before the trans service or after the trans fluid.
Thank you for any guidance or help you can give me.
- in this case with the 4+3 pan, is one of the few circumstances id use “the right stuff”. only because the pans are typically very mishapen. yours may be original. if yes, personally id use hylomar with a gasket, applied properly. hylomar has a spexific application technique.
- this is something i would do, yes. Ive seen more and more cases on this forum where it just needs to be cleaned and then function is restored. so its likely building up gunk.
- i used dex 3, non-synthetic.
- if you are flushing the cooler lines from the 4+3, u can turn your pressure down on the air, and blow it out. this will mean u may have to top up the fluid a second time after you fill.
pics!!! post pics! i personally am a huge 4+3 fan. i tracked mine and it was awesome.
