I purchased my car from a dealer that had the transmission serviced and it's overfilled now I have a leak back by the pan should I drain fluid and refill it to normal level I checked it when it was hot and it was above the full line is it normal to leak out when it's over filled??
You posted in Introductions, place to say Hi and be welcomed to the forums. You seem to want tech info on your 1984 Corvette.. I see that is what you have in your profile, so I moved you here to possible get an answer you seek.
Introductions are for welcoming you to the forum, not tech. I have moved u here to reach folks. It appears you have a 1984 Corvette according to your profile. Good Luck
