VSS on a 91
Old Mar 22, 2021 | 01:05 AM
mcm95403's Avatar
mcm95403
Default VSS on a 91
I'm wondering if the VSS ties into the EFI for any reason, or the cruise control. Basically, if the VSS was broken would it affect anything other than the speedo and odometer?
Old Mar 22, 2021 | 01:19 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Upon purchase '90 vert with T56 transplant, the VSS was never hooked up and upon decel to a stop, the engine would always stall.
Old Mar 22, 2021 | 06:21 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
The VSS on your 91 goes to the ecm, from there it goes through the firewall and splits 3 way's, I can not remember if it goes to the ccm first but it feels the speedometer, the radio, and the cruise control.
Old Mar 22, 2021 | 07:39 AM
WVZR-1's Avatar
WVZR-1
If the car is an FX3 the VSS signal would go to the FX3 from a splice prior to the ECM, if speedo & odo are correct you can assume the ECM has corrected VSS to CCM and the splice to CC and SCV are in tact. Functionality requires confirmation.
Old Mar 22, 2021 | 09:01 AM
MatthewMiller's Avatar
MatthewMiller
Just to add to the replies, the VSS will also affect the way the engine runs. In particular, as you coast or brake to a stop it will want to die.
Old Mar 22, 2021 | 06:27 PM
mcm95403's Avatar
mcm95403
That's odd but interesting to know. Thanks.
Old Mar 22, 2021 | 06:28 PM
DWAVette's Avatar
DWAVette
Does the VSS adjust the radio volume? Just wondering why it goes there?
Old Mar 22, 2021 | 07:00 PM
eutu1984's Avatar
eutu1984
Yes the VSS also control's the factory radio volume.
Old Mar 22, 2021 | 07:02 PM
eutu1984's Avatar
eutu1984
I had the VSS wire short out going from the ecm in under the dash, it courses all sorts of problems with my speedometer and cruise control.
Old Aug 15, 2021 | 05:07 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
What sort of symptoms were you having? Did it go to "0" intermittantly? I have one here that goes to 0 and the cruise cuts out when that happens.
Which wire was it that you repaired?
Thanks,
Jebby
To VSS on a 91
