84 C4 changed Ignition control module, now misfiring
Old Mar 24, 2021 | 04:09 PM
Benny Meraz's Avatar
Benny Meraz
1st Gear
Default 84 C4 changed Ignition control module, now misfiring
So yes i have a 84 Corvette that i changed the ignition control module because it wouldnt start up when warm, but now its misfiring and running bad. I have no idea what is the issue here. Any help is appreciated thanks.
Old Mar 24, 2021 | 06:04 PM
corvettenorway's Avatar
corvettenorway
Distributor Control Module
Old Mar 24, 2021 | 07:11 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
If you are talking about the module under the dizzy cap and it wasn't running like that before you replaced the module, then either the module is bad, you didn't put enough heat transfer grease under it and it is now getting hot or if you removed the coil to do this job, you put it back together incorrectly and it is now misfiring. The other would be that you removed the entire dizzy to this (which you don't) and you stabbed the dizzy back in incorrectly and it is running badly. So, which is it?
To 84 C4 changed Ignition control module, now misfiring
