1989 L98 engine miss
Old Apr 5, 2021 | 11:21 PM
DallasP2091's Avatar
DallasP2091
Default 1989 L98 engine miss
Guys and gals, could use some opinions here.
I have a 1989 with the L98. I just completed a full tune on the car: distributor cap, coil ,rotor, plugs and wires: all new. The car starts but it has a miss at any throttle. It definitely runs better but now I think I have a non-functioning injector because there are no codes being thrown.
Is there an easy way to check these with a meter?
If it is an injector, I will replace or rebuild all eight injectors.
TIA for any advice.
Old Apr 5, 2021 | 11:43 PM
aklim's Avatar
aklim
Which style do you have for injectors?
Old Apr 5, 2021 | 11:45 PM
aklim's Avatar
aklim
Check fuel pressure. Turn the key on and not running should be about 42 psi. Turn the key off and see if it bleeds down quickly. Do a WOT run with the gauge taped to the glass and see whether the pressure is right or not.
If your injectors are Multecs, go to FIC and get a reman set and throw these into the landfill.
Old Apr 6, 2021 | 06:19 AM
kgrover's Avatar
kgrover
Cruising
Did you reset the computer by disconnecting the battery when you did the tune up? It could be that the computer needs to adjust to the new components a bit. I had a bad part throttle miss that didn't go away after I changed a bunch of stuff, but it did once I reset the computer. I also found that checking the idle speed adjustment makes a big difference. My TPS sensor was off a bit and I think that with the ECM not seeing the throttle at idle, it was causing problems. It was only off a touch, but that small adjustment made a big difference.
Old Apr 6, 2021 | 07:25 AM
mudslide's Avatar
mudslide
Test the injector wires with a noid light the check the injector coils with a multi meter , the procedures for these tests are in here somewhere, I did it 16 years ago and had two half *** injectors. Also while running I remember pulling one injector wire off at a time and listen or check tach for one that makes no difference and then trouble shoot that cylinder or cylinders could even have screwed up a plug or wire during tuneup?
Old Apr 7, 2021 | 12:22 PM
DallasP2091
[QUOTE=aklim;1603260276]Which style do you have for injectors?
I assume they are the stock Multecs but I’m not sure.
Old Apr 7, 2021 | 01:22 PM
aklim's Avatar
aklim
[QUOTE=DallasP2091;1603267830]
There is the picture. Go look.
To 1989 L98 engine miss
