1990 Start problem!!!
Old Dec 13, 2002 | 03:23 AM
C490Vette's Avatar
C490Vette
Default 1990 Start problem!!!
I have been having problems starting my 1990 Corvette mostly when the engine is hot and the weather is hot. Only twice has it not started when it was cold. I have already checked the starter and there is no power getting to the starter when the key is turned. I do here the click from behind the dash but it dosent even try to crank. I have tried all my spare keys to no avail. I have also installed a VAT bypass switch and still, it doesnt start. I am running out of options and the dealership is charging me major $$$ to tell me "I dunno!" If anyone can help it would be much appriciated. Thanx!! :confused:
Old Dec 13, 2002 | 04:16 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 1990 Start problem!!! (C490Vette)
Could be the starter, but first try wiggling the shifter in Park and in Neutral.
If no help clip a DMM test lead on the starter cable to see if it's getting voltage when you turn the key to Start. If so check the contact to the starter.
If ok, have the starter tested; replace if bad.
Old Dec 13, 2002 | 04:58 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Hmmm, been a member 337 days and here is the first post... :eek: Welcome.
Well, is it a manual or automatic? Manual, check your clutch safety switch. Auto, beats me :crazy:
Old Dec 13, 2002 | 05:03 AM
C490Vette's Avatar
C490Vette
Default Re: 1990 Start problem!!! (65Z01)
Tested and there is no power to the starter when the key is turned. It is an automatic trans. :crazy:
Old Dec 13, 2002 | 08:32 PM
jfb's Avatar
jfb
No power to the starter solenoid terminal on the starter? Since you hear a click behind the center of the dash, your start enable relay is working although its contacts could be defective (not likely). On automatics, there is a switch on the gear selector lever to only allow cranking in park (maybe neutral too). It sounds like your switch is not activated and is not passing 12v from the crank position on your ign sw to get to the starter solenoid on the starter. If you don't have 12v on the large terminal on the starter, then you have corroded battery cable connections on the battery. Remove both batt cables (neg first), clean the cable lugs and the batt terminals and replace (neg last). Measure the batt terminal volts when attempting a crank. Battery voltage should not fall below 9.0 volts or the battery is discharged, poor cable connections, or the battery is at the end of its life.
Old Dec 13, 2002 | 09:29 PM
ittlfly's Avatar
ittlfly
Default Re: 1990 Start problem!!! (jfb)
It sounds like your park neutral switch is bad or needs adjustment. Although, check your battery posts etc. as the above post recommends.
To 1990 Start problem!!!
