1987 4+3 overdrive problem
Old Apr 11, 2021 | 07:21 AM
Wheels55's Avatar
Wheels55
Default 1987 4+3 overdrive problem
hello all, I am trying to isolate an issue I'm having with overdrive in my 87 4+3, I would like to bypass the ECM to rule out(or in) a control issue, there is conflicting info on the web concerning the wires that need to be spliced together going to the ECM to make OD manual control, does anyone know which wires these are on an 87, color or pin #?
Old Apr 11, 2021 | 11:14 AM
Wheels55's Avatar
Wheels55
Update;. I think I found my issue, a loose connection at the overdrive unit was not making good contact, will put a few miles on it to make sure.
