VATS programmed deleted, Chip/resister key still needed?
When I had a new prom burned I had the VATS deleted. Can I go to a regular non resister key? I need some spares. Also he mentioned something about bypassing the starter interrupt relay for safe measure.I want to be rid of VATS completely...car is an 87.
I wouldn't think so! You could have your key copied to a known erroneous 'resistance' and if you get CRANK then you're good. Do you know the current 'resistance' value of your keys? Put a resistor in line and the key would become usable and consider VATS/CRANK defeated.
The only blank with 0 resistance is a 'brass work key' - you wouldn't want that for everyday use. Once defeated you have no concern for the 'resistance' of the blank used.
If you have multiple working keys now I don't understand the concern. Buy correct spares and if it becomes required add the resistor later.
Car only came with one ignition resistor key. I had the VATS deleted with a new prom. I didn't want to order a resistor key if a standard one can be cut to start the car. It's a # 12 6 ohm key . Also the guy who programmed the VATS delete mentioned bypassing the starter interrupt relay for safe measure, whatever that means... I guess I should just have a standard key cut and see what happens. I just want to eliminate all VATS variables from the car...
A standard blank doesn't have the correct reach. A 'brass' work key has the correct reach but certainly not desirable. If it became an issue later deal with it then. The only practical issue that could be an issue is maybe replacing the actual lock cylinder in which case you'll have key blank issues regardless of what you do.
You no longer need a key with a resister after VATS is deleted in the prom. Now you can get keys cut at Walmart!
not entirely true - you do need to bypass the starter interrupt/enable relay (behind driver info center), too, or the engine won't crank without the vats key.
Well thank God I only wasted 5 dollars. A standard key WILL NOT engage the tumbler inside to turn ignition. I ordered a resistor key at ACE hardware. Gut said it probably would not work but it was an experiment.
The way I interpret the wiring diagram from a 1988 FSM, the VATS module grounds the Starter Enable Relay which is behind the radio / DIC oin the center stack. Without the resistor, the VATS module won't enable the relay for cranking.
The OP's guy is correct: The relay needs to be bypassed before the OP can remove the resistor. In the 88 schematic, the relay has 2 large gauge yellow wires, one large gauge grn/wht wire, and a small gauge dk green wire. Splice or jumper one yellow wire to the grn/wht wire. The other two remain not connected.
I'll check it out. I assumed when the VATS was deleted from the prom , the car will start if the resistor connection fails in the ignition when turning the key. My goal is just to eliminate possible VATS failures leaving me broke down. This car has been frequently breaking down due to age. Almost everything that can fail has been replaced.
This is spot-on. Terminal A will have the grn/white wire, and C & E should have the yellow wires (the connector will give the terminal id's in tiny letters for you to see if your eyesight is good). It doesn't matter which yellow wire you use, just protect the unused yellow wire one from potential grounding.
You are correct. Sorry about my mistake. I had forgotten after almost 20 years about the starter enable relay. My relay had previously failed so as a temporary emergency fix (permanent?) I pulled the cover off the relay and zip tied the contacts closed. The ECM no longer cares if there is a resistor key. And a non vats key will work unless they screw it up when they cut it.
Yep, and nothing beats getting stranded 400 miles from home because your car that no one else really care about (as in enough to steal) won't start due to yet another crappy 35 year old relay that was marginal when new was inserted into yet another branch of the wiring harness behind the dash and won't close the contacts when you turn the key - BTDT!
My apologies but I'm not savvy when it comes to electrical not having it in front of me. Remove relay and specifically jump which wires to bypass?
Easy peasy. Remove relay and connect either of the thick yellow wires to the thick grenn-with-white-stripe wire. Then just make sure to protect the yellow wire that you're not using so it can't short to ground (i.e. don't leave a bare wire end dangling around back there).
