convert from column to dash ignition?
Old Apr 11, 2021 | 02:13 PM
mcm95403's Avatar
mcm95403
Default convert from column to dash ignition?
Anyone here ever done this? I'm wondering if a C5 ignition switch could be used to convert over, getting rig of the column switch.
Old Apr 15, 2021 | 12:41 AM
mcm95403's Avatar
mcm95403
Bueller...........
Old Apr 15, 2021 | 01:25 AM
ChumpVette's Avatar
ChumpVette
Do it in race cars. But I don’t use a factory column.
Are you going to reside everything that requires key on ignition power and remove the column lock?
Old Apr 15, 2021 | 01:31 AM
snlshow's Avatar
snlshow
Just curious...what is the motivation behind this?
Old Apr 15, 2021 | 08:44 AM
Aardwolf's Avatar
Aardwolf
I have the Longacre switch panel push button start in mine now. I leave the key in the run position till I can replace the column with a racing model.
https://www.longacreracing.com/produ...6-pilot-lights
Good product, comes with directions for wiring.
Old Apr 15, 2021 | 09:10 AM
RUU's Avatar
RUU
C5 Column lock bypass envy?
Old Apr 15, 2021 | 11:44 AM
mcm95403's Avatar
mcm95403
The idea was to get past the column lock (no C5 CL envy :P ) and not have to reach around the wheel for an "invisible" key slot. Not a "I must do this" more of a "hmmm, that could be cool" thing.
Old Apr 15, 2021 | 12:41 PM
Kevova's Avatar
Kevova
IMO Converting to a keyless transponder where you only have a push button start on the dash ; isn't going to be a simple plug and play process. Going to dash key switch, the only obstacle is deciding where to mount cylinder. Several later models used dash cylinders. Bypassing lock in column is simple just remove locking pin and retainer.
Old Apr 16, 2021 | 10:28 AM
mcm95403's Avatar
mcm95403
Not looking for Keyless or anything like that - the less computerized/electronics the better.
To convert from column to dash ignition?
