What is this thing?
Old Apr 14, 2021 | 06:24 PM
Alejandro Guerrero's Avatar
Alejandro Guerrero
Default What is this thing?
As I'm putting things back together I found this but have no recollection of it nor could I find it in the FSM
Old Apr 15, 2021 | 06:18 AM
kenmohr's Avatar
kenmohr
Pic
Old Apr 15, 2021 | 06:23 AM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Must have found a home for it.
Old Apr 15, 2021 | 09:23 AM
Alejandro Guerrero
Fixed it, could've sworn I uploaded the first time
Old Apr 15, 2021 | 09:35 AM
belairbrian's Avatar
belairbrian
looks like the splash shield from under the intake
Old Apr 15, 2021 | 09:41 AM
WVZR-1's Avatar
WVZR-1
GM# 14087401 is quite likely for a L98
*** LT1 early looks to attach differently but maybe SPO error? It is an SPO image error!
Old Apr 15, 2021 | 09:42 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
and we have a winner!
Old Apr 15, 2021 | 09:43 AM
Alejandro Guerrero
It had to have come of my lt1 as it's the only engine I have taken apart. I tried to find it in the diagrams for putting the intake in and couldn't, looks like I get to take it off again and figure out where it goes.
How important is it that it goes on...
Old Apr 15, 2021 | 09:55 AM
WVZR-1's Avatar
WVZR-1
It had to have come of my lt1 as it's the only engine I have taken apart. I tried to find it in the diagrams for putting the intake in and couldn't, looks like I get to take it off again and figure out where it goes. .
What year is your LT1? The shield for a '92 or '93 looking at some SPO LT1 engine images looks to attach differently.
All '92+ LT1/4 part #'d as 10128305 BUT a second look mentions 4 bolts so the image (in early SPO) is in error.
Old Apr 15, 2021 | 10:07 AM
Alejandro Guerrero
A '92 or '93 is part #'d as 10128305 BUT a second look mentions 4 bolts so the image is in error.
My car is a '94, so that the only thing I can think of that it would have come from. I have bought some used parts from other years, mainly '96 but I feel like if I bought this I would remember.
Old Apr 15, 2021 | 12:04 PM
ajp01's Avatar
ajp01
This part, the splash shield that bolts to the bottom of the intake lower manifold.... It seems to me that it doesn't have much oil splash to control or shield where it's located in the valley, but I do think it's there really to prevent those 4 hex head threaded plugs in the EGR gallery from coming loose and falling into the engine. If those somehow unscrew themselves from the bottom of the manifold there is a risk that they could fall into the oil drain at the back of the block and into the cam / crank / whatever. The chances of that really happening are very low at most...
You can see the holes in the bottom of the intake when these plugs are removed in the photo... If it were me I don't think I would open up that motor since this part is sort of a safety more than anything else. You'll probably need to take the manifold off for something else soon enough anyway, why not wait until then?
Old Apr 15, 2021 | 06:27 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
If the bolts backing out are a concern, drill each bolt head and safety wire them. They will never come lose like that.
Old Apr 16, 2021 | 12:22 AM
xrav22's Avatar
xrav22
The L98 has 4 square bolt pattern. Just discussing.
To What is this thing?
