1986 L98 engine. Just breaking it in and I have the at idle reading set at .540 volts. At WOT I can only get it to 3.8 volts but I am under the impression it should be at least 4.0. The issue I am trying to resolve is a miss at WOT. I am also going to check my plug wire routing. It’s a new tps switch, but that doesn’t mean anything these days. Looking at simple things first. Thx.
So, the question is this:
Is the throttle body opening all the way as much as it can?
If no, then cable adjustment or replacement is necessary. If yes, then try removing the TPS and measuring it OFF the throttle body.and see if it actually is capable of going to 4.0.
If no, then you need to replace it.
If yes, then possibly remounting it may change things, but at that point, I'd be looking again at the throttle body.
LiveWire I think it is opening. I will pull the pieces off the front of the TB to verify. Then I will pull the TPS off the TB and just move it by hand. I just wanted to confirm that my 3.8 or.9 was too low a reading, then figure out why. This engine is in a C3, so nothing is stock but the pedal is pulling the TB open as far as it will go with the stop at the top of the linkage making contact with the houseing. I Will follow up later when I get it apart. Thx.
Move the throttle by hand, then measure TPS. If it goes above 4 then it's the pedal/ cable issue. Regardless, you misfire has nothing to do with the TPS signal.
Disconnected all linkage and cannot get it over 3.9. Throttle wide open. Took the switch off and by hand I can get it to go up to almost 5.0, but I can't get that number with it installed without the .540 at idle being off. So it is the switch. As for it not affecting the misfire, seems to me in previous vehicles that the TPS was one of the most critical components telling the computer where the throttle was positioned, and that voltage to the ecu translated to a signal going to the injectors regulating fuel somehow. Not an expert by any means but it must have something to do with throttle/fuel/air or why would it be attached to the throttle blades.
It does seem to be off. But the MAF sensor is the load sensor that the ecm uses for fuel calculation. What part number TPS did you buy? You need to isolate the misfire as to whether it's one cylinder or more.
you are saying that even rotating the tb by hand you canny get the tps to read over 3.9?
but if you rotate the tps lever by hand it will go full range?
how open are your throttle blades in the resting position? can u upload a bunch of pics
Correct. If I take off the throttle cable and the trans kickdown cable, take off the hose connecting throttle body to air filter I can move the blades so they are wide open, I can only get it up to 3.8 or maybe 3.9. If I take the sensor off the throttle body and move it with my hands I can get it over 4.0. I definitely seems like the switch is bad. Like there isn't enough available travel when hooked to throttle body. I will try and get some pics tomorrow. When the blades are resting, my idle is perfect at about 650rpm. And the voltge is .540, which is in spec. I even tried backing off the idle adjustment screw completely and it did not make any difference in reaching the over 4.0 number. Then I had trouble getting it back to the .540. Thanks for all the feedback.
3.8-3.9 volts at WOT should be fine. You only need enough tps voltage for the ecm to enter power enrichment mode which normally occurs at 70% throttle. This can occur below 3 volts.
Observe the throttle position and target afr signals. Due to the rapid rate of throttle opening and slow sample rate, you can't see the exact voltage the instant that power enrichment mode is entered, but you get the idea. Power enrichment mode entry can be seen when the target afr drops below 14.73. In this case, 14.73:1 -> 12:1. Power enrichment exit can also be seen later on as the throttle is closed.
