Gearshift Knob (4+3) Alignment
Old Apr 19, 2021 | 04:24 PM
lastofhiskind's Avatar
lastofhiskind
Default Gearshift **** (4+3) Alignment
On my recently acquired 1988 C4 (with manual 4+3 transmission) the gear shift ****, which is roughly rectangular, doesn't point forward. It's actually turned a little bit to the left, counter-clockwise, towards the left front wheel. I'm sure this wouldn't bother some people at all but I've got the sort of personality where this will quickly drive me nuts. Is there a straightforward way to fix the alignment? I have instructions on how to remove the **** but it isn't clear how you would change the angle at which the the **** becomes tight as you screw it down in order to fix the alignment.
Thanks!
Old Apr 20, 2021 | 08:54 AM
PacerX's Avatar
PacerX
Thanks!
I'm trying to remember because I haven't had mine off in a while but I don't think it screws on... it has a steel press fit key that locks it in place and the keyway may be worn.
Sometimes people who don't know how they come apart start twisting and damage the ****/keyway.
If that's the problem the only solution is a replacement ****. Mine points the right direction, but the plastic tabs that hold the button are on their last legs, so it may be time for a new one for me too.
Old Apr 20, 2021 | 12:06 PM
PacerX's Avatar
PacerX
Originally Posted by ihatebarkingdogs
PacerX is describing the automatic which pushes on, and is held with a C-clip.
The 4+3's screws on, but not until it is tight. Screw it on until snug, then back off until it is oriented straight ahead. There is an aluminum "H" shaped wedge that goes into the **** against the flat on the shifter stem that keeps it from turning, and locks it in place. Sounds like the OP's wedge is missing.
There is a small diameter metal "T" piece that screws into the OD switch at the base of the shifter. This must be removed prior to attempting to unscrew the ****. Be very, very gentle prying up the plastic center button. There is a "C" shaped clip in each corner. The front two are on the metal rod to the switch, the rear two hinge on the shift ****. Gently pry up on each corner, just a tad. I haven't seen the plastic button for the 4+3 catalogued by any of the regular sources. It may not be available if the clips get broken off..
Mine's a stick... But my memory is bad!
Old Apr 20, 2021 | 04:32 PM
InfomanSS's Avatar
InfomanSS
Pry the button gently from the FRONT edges. When removing the T-Rod, count the number of turns it takes to remove it, then when you reinstall go with the same turns back. It doesn't have to be exact, but this will determine the height of the button when reinstalled.
Old Apr 20, 2021 | 07:34 PM
lastofhiskind
Thanks! This is super helpful.
To Gearshift Knob (4+3) Alignment
