How do you flush transmission lines?
Old Dec 13, 2002 | 05:59 PM
VetBoy89's Avatar
VetBoy89
Default How do you flush transmission lines?
When you installed a new/rebuilt transmission, what method did you use to flush the cooler lines.
I don't have a compressor so I was going to do it like this:
1) Disconnect lines from radiator (already disconnected from trans)
2) Use brake cleaner or carb cleaner and spray it through the lines then flush with water.
3) Use brake cleaner or carb cleaner and spray into radiator then flush with water.
Does this sound like a proper method or is there a better way? :smash:
Thanks a bunch guys!
Old Dec 13, 2002 | 06:59 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: How do you flush transmission lines? (VetBoy89)
:cheers: :D
If pipes are disconnected at both ends, use your internal compressor! :D
Blow through the line.
I would stay away from carb cleaner, water, etc. Smoe may linger in the lines.
Not sure what you are trying to accomplish? :D
Jack
Old Dec 13, 2002 | 11:30 PM
john25's Avatar
john25
I got a can of aerosol transmission line cleaner from the trans shop that rebuilt my conv trans. It has a hose with a female threaded connecter that your trans line connects to. Spray 1/2 can of cleaner through one line and then switch lines and spray the rest through. Then blow it clean with the compressed air. These are the directions on the can as best as I can remember them. :thumbs:
Old Dec 13, 2002 | 11:33 PM
scorp508's Avatar
scorp508
Don't use brake cleaner. Whatever seals it comes in contact with could deteriorate them some. You don't ever want brake cleaner on anything besides metal.
To How do you flush transmission lines?
