Black or Blue ZF?
Old Apr 30, 2021 | 10:47 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Black or Blue ZF?
Which is better a black or blue labeled ZF? Why what the difference?
Old Apr 30, 2021 | 04:17 PM
Beater12's Avatar
Beater12
Black was the earlier one and was stronger than the Blue. As I understand it the black had straighter cut gears which made it stronger but was fairly noisy. The blue tag had more angle cut gears which made it quieter. I have a black tag in my 90 and I can definitely hear it whine while accelerating in first gear.
Old Apr 30, 2021 | 07:31 PM
95wht6spd's Avatar
95wht6spd
I can hear mine in my 95, so the black tags must be really loud. Anyone know the % difference in strength, or what each is rated for?
Old Apr 30, 2021 | 09:08 PM
Beater12's Avatar
Beater12
There are other post that state the difference and what they are rated for. Maybe do a search?
Old May 1, 2021 | 12:27 AM
cv67's Avatar
cv67
St. Jude Donor '05
Thought it was 450 and 400 lbs something like that?
Its always more than GM recommends to be safe. Im a sucker for a loud manual trans, loved the whine.
Wish I could afford a gearset like that for a T56
Old May 1, 2021 | 10:04 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Try looking at zfdoc.com for a lot of info.
The black tag was rated at 610 Nm torque capacity.
The blue tag was rated at 540 Nm torque capacity.
Like others stated the black tag has more straight cut gears than the blue tag and the black tag makes a little more noise.
The input shaft guide is a different diameter between early and late cars so they use a different throwout bearing that slides over it.
Not specific to black or blue, the blue has some differences. The '94 blue tag uses a lift ring for reverse lockout, but the '95 & '96 use a "crash through" design that does not use a lock ring but uses more effort to push through to reverse. The black tag has some differences too such as a different speed sensor in the early years.
In practice there is very little difference. Both are very strong and even behind high horsepower motors they last well. I have both black and blue ZF's and I don't notice the difference in noise.
Although I like the thought of a stronger transmission, I like the '95-'96 shifter. So for me it makes almost no difference and currently have one black tag and one blue tag and like both.
Good luck.
Old May 1, 2021 | 01:01 PM
Bill Chase's Avatar
Bill Chase
best answer.. whichever one you can get with the lowest miles and decent price is the best option. you will be well over 500 horsepower before you start taxing either unit. so get whats available and affordable. make sure when you buy it the seller includes all of the bellhousing parts, shims, throwout arm, pivot bolt, hydraulic line. and all bolts. if someone took the time to completely remove it and properly gathered all the hardware you can be relatively sure it is in decent shape.
To Black or Blue ZF?
