SuperRam install questions
Old Dec 14, 2002 | 10:09 PM
chucks88's Avatar
chucks88
Default SuperRam install questions
Are these correct?
A=brake booster connection
B=vacuum from EGR solenoid
C=vacuum from FPR
D=blocked off MAP sensor
MAT sensor under plenum
I'm thinkin "B" and "C" makes no difference
Where do I get the nipple connections for "B" and "C"? The holes are threaded but no nipple(I just like saying that) connections
What is this evaporation canister that I have read about? Something else I need to add?
Thanks boys,
Chuck
Old Dec 14, 2002 | 10:55 PM
scorp508's Avatar
scorp508
Default Re: SuperRam install questions (chucks88)
A is vacuum supply for brake booster
B is vacuum supply for HVAC and Cruise Control (they branch off of each other)
C is vacuum supply FPR and EGR (they branch off of each other)
D you can just put a pipe plug in, thats for the MAP sensor.
Can the nipples be screwed off of the original plenum? I forget, my SR came with some.
The Evap cannister doesn't connect to the plenum.
Old Dec 14, 2002 | 11:21 PM
MrNuke's Avatar
MrNuke
Default Re: SuperRam install questions (scorp508)
I can't wait to see/hear what your new toy will do... :cheers:
Old Dec 15, 2002 | 08:30 AM
chucks88's Avatar
chucks88
Ahhhh, I think they do screw off now that you mention it.
So what does the vapor canister do, It's probably fuel related but I don't remember seeing anythink like that during my last tear down.
Old Dec 15, 2002 | 10:49 AM
scorp508's Avatar
scorp508
It collects the vapors from your fuel tank that create positive pressure in the tank. When the cannister gets to a certain point it purges the vapors into your throttlebody to be burned.
Old Dec 15, 2002 | 06:29 PM
MITCH's Avatar
MITCH
chuck you are wasting no time how long did it take you to get home.
mitch :seeya
To SuperRam install questions
