Fan stopped working....
Old Dec 15, 2002 | 07:08 AM
mayberry's Avatar
mayberry
Default Fan stopped working....
What steps should I take to narrow the problem down to relay, or fan motor? I have a feeling it is the motor since I found a piece of my shredded belt wrapped around it, but want to make sure before I replace it. Thanks in advance.
Old Dec 15, 2002 | 10:48 PM
don hall's Avatar
don hall
Default Re: Fan stopped working.... (mayberry)
You should have a 3 amp fuse identified as "C Fan" located in the second row from the top, and the last fuse on the right in that row. Your belt may have "strangled" your fan, blowing the fuse. If the fuse checks OK, then you might apply 12 volts directly to your fan motor to determine if your fan responds to voltage. If the fan motor doesn't respond to direct 12 volts, it is quite likely that your motor needs replacing.
