Rebuilt steering rack
Old May 18, 2021 | 08:41 PM
RicardoG's Avatar
RicardoG
Default Rebuilt steering rack
Car is a 94 LT1 with 112 000 miles .
New Golen 383 with LE2 top end. everything has been refreshed or rebuilt besides the rack...
I have some slop in my steering. I have checked the rag joint and it is not the cause of the slop.
The slop definitely resides withinin the rack Itself.
Are the rebuilt steering racks any good? Is it opossible to adjust in order to get rid of the slop?
The unit does not leak.
Thanks for any advise.
RG
Old May 18, 2021 | 09:47 PM
ChumpVette's Avatar
ChumpVette
Turn 1 is the only place to consider for a rebuild. I would also recommend sending your PS pump in as well.
Old May 19, 2021 | 12:26 PM
ctmccloskey's Avatar
ctmccloskey
I second the Turn One recommendation from ChumpVette!
The folks at Turn One have been building my P.S. Parts for years. Good suggestion to include your Power Steering Pump as well.
Old May 19, 2021 | 04:40 PM
Yinzcity's Avatar
Yinzcity
X3 for turn one. A lot of the rebuilt racks and even the supposedly "new" rack I purchased from rock auto have a larger hole for the mounting bushing than stock which means you can't install them unless you make a custom bushing. Learned my lesson, will be going to turn one next time.
Old May 20, 2021 | 11:10 AM
9T3VETTE's Avatar
9T3VETTE
x4 for Turn One. Had my 93's rack and PS pump rebuilt last year. Impressed with the service and products.
Old May 22, 2021 | 10:36 AM
Went's Avatar
Went
Turn 1 rebuilt my rack.
Old May 23, 2021 | 11:26 AM
RtStuf's Avatar
RtStuf
What is benefit of having power steering pump rebuilt or how do you know when it needs to be rebuilt?
Old May 24, 2021 | 01:32 PM
ctmccloskey
They can match/verify the flow from the pump and make sure that it is the right part and they are compatible. They can also tell from the flow rate if your pump needs service or not. I have used them several times regarding my C3 power Steering primarily as the pumps output pressure was causing problems.
One lesson I walked away with from them is the Standard "Heat is your Enemy", I have installed TUBE coolers on the PS fluid systems to keep the fluid cooler to help my racks last longer. Cooler Power Steering Fluid will help get many more years of service before rebuild time again. I also increased the reservoir size on the C3 to get a larger volume of PS fluid which also helps keep it cooler.
TURN 1 has quite a following on this Forum! There must be a reason for that... They do great work!
Old May 25, 2021 | 05:28 AM
cv67's Avatar
cv67
St. Jude Donor '05
Good to hear theres an alternative to cardone...getting the rack out on most cars is a job I wouldnt want to do once let alone twice.
Op have you jacked the front up..have someone turn the wheel back and forth and see if you can identify any sloppy points? Could be a few things.
To Rebuilt steering rack
