msd digital 6
Old Dec 15, 2002 | 04:47 PM
RedyGo's Avatar
RedyGo
Default msd digital 6
does any body know what i have to do to make my factory tach work after installing an msd digital 6. above 3000 rpm it goes to 0!! :chevy
Old Dec 15, 2002 | 04:51 PM
scorp508's Avatar
scorp508
You may need to bypass the factory tach filter. Beleive it or not the tach on my car worked fine still using the tach filter. I was shocked.
Old Dec 15, 2002 | 04:54 PM
StealDads67's Avatar
StealDads67
Default Re: (scorp508)
I didnt have to change anything... My tach works just fine with it... But the manual says if the tach isnt working properly then by-pass the tach filter
Old Dec 15, 2002 | 06:09 PM
RedyGo's Avatar
RedyGo
Default Re: msd digital 6 (RedyGo)
i read that in the manual but im not sure where the filter is :confused:
Old Dec 15, 2002 | 06:38 PM
scorp508's Avatar
scorp508
I wish I could tell you, but I'm not aware of to its location for an LT1. On an L98 they are located on the upper/left bellhousing bolt below the distributor, but you don't have a normal distributor. :)
Old Dec 15, 2002 | 11:01 PM
Nathan Plemons's Avatar
Nathan Plemons
On the original wiring harness, look for the connector that plugs into the coil. Should be the gray and black plug that you disconnected and plugged into your MSD easy harness. Look at those plugs and trace that cable back a few inches. You will come across a small cube, about an inch square or so, that's the tach filter. It should have a white wiring coming out of either side of it, you might have to remove some tape to see this. Remove enough tape to leave you some room to work. Cut the wires going to the tach filter and just splice them back together, leaving the filter unhooked. You might be able to leave yourself enough room to splice back into the tach filter should you ever need to.
Cute how it'll rev all the way up to about 3000 rpm's then go crazy isn't it? :cheers:
[Modified by Nathan Plemons, 10:02 PM 12/15/2002]
Old Dec 15, 2002 | 11:12 PM
scorp508's Avatar
scorp508
I can't remember exactly, but isn't 3000 RPM the spot where the digi-6 switches over from multiple sparks per cylinder to one big motha' of a spark per cylinder?
Old Dec 16, 2002 | 06:30 AM
Nathan Plemons
Somewhere right around in there. I too have wondered if that has anything to do with it.
Old Dec 16, 2002 | 06:25 PM
RedyGo's Avatar
RedyGo
thanks alot ill try it!!
Old Dec 16, 2002 | 06:26 PM
StealDads67
3300rpms, they say after that there is no time to keep firing MSD
Old Dec 17, 2002 | 09:29 PM
RedyGo's Avatar
RedyGo
thanks, it worked :steering:
Old Dec 17, 2002 | 09:32 PM
scorp508's Avatar
scorp508
:thumbs:
To msd digital 6
