How do I drop the driver's side kick panel?
Old May 26, 2021 | 12:50 AM
LWesthaver's Avatar
LWesthaver
Default How do I drop the driver's side kick panel?
Can anyone advise? I want to drop the carpeted panel under the dashboard on the driver's side to gain access to the steering column. I see that there are two recessed bolts under there. Are there other fasteners that must be removed?
Old May 26, 2021 | 09:32 AM
s carter's Avatar
s carter
First we need to know which generation of C-4, square or round dash.
Early years (square) some hidden screws inside the carpet pile and two 1/2" bolts deep inside two holes in underside
Later years (Round)
I believe there are screws hidden inside the pile of carpet about 2" from the top running L to R, and there are 2 more on the side more center. 4 more underneath.
Once you have that out you still need to remove the aluminum crash plate but that is self explanatory bolts are visible
Old May 26, 2021 | 09:37 AM
jrobin1's Avatar
jrobin1
Go to batee.com Corvette Parts and Repair – Batee.com Corvette Parts and Repair and click on the information header tab. Look for the appropriate year car.
Old May 26, 2021 | 03:09 PM
LWesthaver's Avatar
LWesthaver
Sorry, it's an 88. I thought my sig would provide that information.
Thanks for the info. Turns out that it comes apart pretty easily.
To How do I drop the driver's side kick panel?
