L98 full roller rockers, pushrods?
Problem is they are not "self guiding", they need guide plates. My understanding is the stockers have guide plates in there, but the plates and pushrods are non hardened.
By another happy coincidence, I just happen to have an unused set of hardened guide plates gathering dust on the shelf. More leftover stuff from other projects.
Same with valve covers, a set sitting on the shelf, unused. They're not center bolt covers, but I've got a couple center bolt to perimeter bolt plates as well. They even kind of look like the stock L98 covers:
Well, kind of, but not exactly. Whether or not they will clear that wiper motor is another story.....
So I need hardened pushrods.
Question is: do I have to measure new pushrod lengths or can I just order new hardened rods in the OEM lengths?
I'm a little unsure which way I need to go because I've never dealt with hydraulic roller lifters and the need for them to "pump up" to work right. I've changed solid lifters before and have always measured for new pushrods, but how do you measure pushrod length for a lifter that "hydraulically adjusts" as it runs?
Thanks.
That may or may not make things a bit easier.
So when there is no up/down slack in the pushrod give it another 1-2 turn or so, done.
Dont like the "til the pushrod doesnt spin" it doesnt always work .
Dont see why a stock length pushrod couldnt be used. You havent changed anything other than the rocker arm
Check what ever brand you get, there are three ways used to measure a pushrod and diff brands may say the same but be actual diff lengths.
The valve cover will hit the brake booster, did the same on my 86 with an adapter and proform covers that look like those https://www.proformparts.com/product...-logo-sb-chevy Had to notch and weld the cover to clear. Not sure on fronts, I got rid of my AC and air pump but if I rem right when researching it out long ago they prob will hit.
