mass air flow
Old Jun 2, 2021 | 02:12 PM
edwardautry's Avatar
edwardautry
Cruising
Default mass air flow
I have an 1985 C4 and it started rough idle and smells very rich when you give it gas it bogs down. would this be a mass air flow sensor?
Old Jun 2, 2021 | 08:47 PM
aklim's Avatar
aklim
How old is the O2 sensor? Can you try disconnecting the MAF and see if the O2 sensor sees that?
Old Jun 2, 2021 | 10:10 PM
edwardautry
Cruising
i will try that thank you
Old Jun 3, 2021 | 09:14 AM
Mixednuttz's Avatar
Mixednuttz
2023 Corvette of the Year Finalist - Modified
2022 C4 of the Year Winner - Modified
Finalist 2020 C4 of the Year - Modified
Is the check engine light coming on? You can pull error codes on an 85 with a paper clip.
Old Jun 3, 2021 | 04:33 PM
edwardautry
Cruising
no check engine light. it was running fine i changed the shocks and then drove aroud for about 20 mins parked it in the garage and the following day it started acting up. im thinking maybe a vacuum leak, what do you think?
Old Jun 3, 2021 | 06:19 PM
aklim's Avatar
aklim
Did you try to do it with the MAF disconnected?
Old Jun 3, 2021 | 06:36 PM
edwardautry
Cruising
I did not try that, what should happen with it disconnected? I will try it when i get home this weekend.
Old Jun 3, 2021 | 06:39 PM
aklim's Avatar
aklim
If it is a MAF issue, it may do better disconnected since it forces the system to go off the tables thwt are preprogrammed.
Old Jun 3, 2021 | 06:43 PM
edwardautry
Cruising
awesome, i will update you this weekend thank you
Old Jun 3, 2021 | 07:12 PM
aklim's Avatar
aklim
Go ahead to Autozone and borrow their fuel pressure gauge. You might need it unless you have one yourself
Old Jun 9, 2021 | 01:36 PM
edwardautry
Cruising
thank you, when i disconnected the MAF it ran must better just waiting on the part now... I have another question can you tell me if the 1985 has and MAF power and burn off relay and if so where is it located?? again thank you
Old Jun 9, 2021 | 04:51 PM
viii's Avatar
viii
85 has a "burn off module" located on passenger side behind "bread box" on dash. After 85, they went to a simple relay located on firewall. As I understand it, if your module is bad (and I am not sure how you isolate a bad module).. .you'll be going to ebay, etc. looking for a decent used part.
Old Jun 14, 2021 | 11:57 PM
edwardautry
Cruising
Where is the 1985 c4 map sensor located?
Old Jun 15, 2021 | 12:07 AM
Nomake Wan's Avatar
Nomake Wan
It doesn't have one. The '85 uses a MAF, which is located between the air filter and the bellows that connects to the throttle body.
Old Jun 15, 2021 | 12:53 AM
aklim's Avatar
aklim
NOWHERE unless you put one there. You are MAF and not speed density.
Old Jun 15, 2021 | 01:29 AM
ThatOneKid's Avatar
ThatOneKid
Bad modules wont power the sensor or won't trigger burnoff after shutdown, easy to test with a multimeter, after shutoff you should hear couple of faint clicks from behind the breadbox.
Old Jun 15, 2021 | 12:38 PM
Nomake Wan's Avatar
Nomake Wan
For reference, here's the MAF circuit for 85:
To mass air flow
Old Jun 20, 2021 | 03:38 PM
edwardautry
Cruising
Ok iv replaced the mass air and the mass air burn off module behind the bread box and with everything together its running just like it was when this happed... There is no check engine light. Is there anyone who may know what is up with this?
Old Jul 20, 2021 | 01:56 PM
edwardautry
Cruising
OK I have an error code 43 I replaced the knock sensor and it still is running poorly and still have 43 code. If the Coolant Temp sensor was bad would that give me a code 43???
with everything else that has been replaced and tested I think if the Coolant Temp sensor doesn't correct the problem it would be the ecm??
Old Jul 21, 2021 | 02:02 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Code 43 will pull alot of timing off idle and will make the engine feel sluggish. You might want to run through this logic tree before changing more parts.
https://www.corvetteforum.com/forums...post1600002941
