LT4 Thinner head gasket
Old Jun 2, 2021 | 06:16 PM
RandomTask's Avatar
RandomTask
Default LT4 Thinner head gasket
Was planning on running the MR. Gasket 5716G on my LT4. From my understanding this should bump my compression a bit. Block is stock deck but heads were shaved .010" for flatness. Am i to the point i should be concerned with valve clearance? (stock cam btw) Thanks!
Old Jun 2, 2021 | 07:00 PM
JD1964's Avatar
JD1964
The compression on an LT4 is already high enough. If anything, I’d use a thicker gasket to compensate for the milling work.
BTW, milled heads in combination with thinner head gaskets might cause trouble with the intake manifold fitting properly.
Old Jun 3, 2021 | 02:38 PM
Kevova's Avatar
Kevova
The .010 off the head shouldn't hurt anything provided they haven't already been milled. Decking block is a different matter. The piston should be below the deck probably .015 or more at TDC. 0 decking reduces deck height until it is equal to piston height a TDC. Head gasket actually sets the clearance between head and piston. There should be enough clearance that piston wouldn't contact heads at high RPM. You can measure piston to deck distance add to crushed head gasket thickness spec. You should have atleast .040.
The piston to valve clearance is also dependent on piston eye browe depth along with the cam valve lift. .550 or less is probably ok. If in doubt I'm certain YouTube has a how to video; to check piston to valve clearance.
Old Jun 3, 2021 | 04:12 PM
SouthernSon's Avatar
SouthernSon
You might double check push rod length to center rocker over valve stem too.
Old Jun 3, 2021 | 07:42 PM
RandomTask's Avatar
RandomTask
Cleaning the pistons tops in the garage, remembered that when I rebuilt it, the aftermarket pistons I have have larger reliefs than the stock LT4 pistons so I'm not worried about clearance any more. I'll have to check how deep the pistons are in the hole but it's stock. I think it's definitely more than .014" to provide .040 total with a .026 gasket.
Edit: just measured. Pistons .041" in the hole.
To LT4 Thinner head gasket
