I’m getting a new 700R4 beefed up trani. I want the shift point set at 6200 rpm. My builder tells me it can only be done using the TV-cable.
I always thought this is done by the different weights of the governor.
I need help before they put my trani together.
Re: Higher shift with TV-cable or governor weights? (vettef6)
Find another builder! I'm not a transmission expert but the way to change shift points is with the govenor weights and springs. There is really only one correct postion for the TV-cable.
