1984 Engine
Old Jun 10, 2021 | 04:45 PM
Sharls's Avatar
Sharls
2nd Gear
Default 1984 Engine
I have a question.
Can you please tell me if any 350 block engine fit on a 1984 corvette?
Old Jun 10, 2021 | 04:51 PM
84 4+3's Avatar
84 4+3
Originally Posted by Sharls
I have a question.
As long as it is a 2 piece rear main seal any one should work.
Old Jun 10, 2021 | 04:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Any two piece rear main seal block will fit on a 1984 Corvette. That would be '85 and older, IIRC.
You could use a newer, 86 and up, one piece rear main seal block and it will "fit", but you would have to change to a newer flywheel, as the crank flange is different for the one piece seal.
Old Jun 10, 2021 | 05:17 PM
Sharls's Avatar
Sharls
2nd Gear
thanks
To 1984 Engine
