Fuel Pump 2 pin connector
Old Jun 12, 2021 | 10:25 PM
mcclr's Avatar
mcclr
1st Gear
Default Fuel Pump 2 pin connector
I purchased a new fuel pump for a 1985 . The old pump had two spade terminals while the new Delphi FE0110 pump has two small round terminals that look like it may need a 2 pin connector to plug into it. The new pump did not come with a connector and there was no mention of needing to rewire to use this new pump. Can anyone please give some advice as to where the compatible plug can be found or how others have gotten the Delphi FE0110 to work in an 85 C4?
Thanks, Larry
Old Jun 13, 2021 | 08:12 AM
ThatOneKid's Avatar
ThatOneKid
I believe the pump uses the standard walbro connector looking at some pictures, I can't say it's 100% but it looks close.
Amazon Amazon
Old Jun 13, 2021 | 08:41 AM
WVZR-1's Avatar
WVZR-1
If you're in the USA or Canada carry your new pump to an auto parts store and it's very likely they will have the 'pigtail' on their shelf! Did you buy what you've got 'local'? If NOT you should have - you'd then have someone that you could have gone back to and ask questions!! Buy 'LOCAL' always!
Where did you buy it?
I ain't seen your purchase but this information should get you what you need.
A GM# I believe would've been 25117765 but the autoparts store will have less expensive in another brand. PT352 or S722 might be informtion they can cross-reference also.
To Fuel Pump 2 pin connector
