96 Coolant Temp Sensor
Old Jun 14, 2021 | 10:52 AM
RandomTask's Avatar
RandomTask
Default 96 Coolant Temp Sensor
Lt4 car, does the ecu care if it's getting coolant temp data? (As in will it adjust timing/performance?) From my research, it will throw a code saying the sensor is whack. That stated, its a track car and I have a gauge to monitor the temp. I used to have the sensor plugged into the back of the passenger head which was giving me a bad reading (too high). Wanted to replace the coolant temp sensor and utilize that port for the gauge sensor.
Old Jun 14, 2021 | 11:42 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Yes. There are numerous settings and numerous tuning tables that take coolant temp into account.
Old Jun 14, 2021 | 12:20 PM
RandomTask's Avatar
RandomTask
Thanks! Guess I'll put the ecu temp sensor back in and move the gauge sending unit to one of the heater core ports I tapped and blocked off.
To 96 Coolant Temp Sensor
