VHT High Temp Caliper paint
Old Jun 15, 2021 | 08:10 PM
Hawkeye56's Avatar
Hawkeye56
Default VHT High Temp Caliper paint
I am repainting my rotors on both sides excluding the pad area I taped off.
I used there primer and now painting everything else black.
My question is do I have to bake the rotors at 200 degrees for a hour or will the natural heat cycles do the same thing?
Thanks Hawkeye56
Old Jun 16, 2021 | 09:08 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
https://www.vhtpaint.com/high-heat/vht-caliper-paint
either, read the above
since you probably don't have a spare oven to bake them in, you could get a paint chemical smell in the house oven if you did them there, so ......................
Old Jun 16, 2021 | 09:33 AM
Hawkeye56's Avatar
Hawkeye56
I have them off vehicle now and it will be weeks before driving, So since I do not have a spare oven I will assemble and let normal curing take place.
Thank You
Hawkeye56
Old Jun 17, 2021 | 11:31 AM
SLVRSHRK's Avatar
SLVRSHRK
I cured mine on the grill on my deck. Did manifolds and calipers and has held up very well.
Old Jun 17, 2021 | 12:13 PM
ctmccloskey's Avatar
ctmccloskey
I use an oven in my garage to bake my Powder Coated parts. It is never used for anything but powder coating it wouldn't hurt anything or poison anybody.
A Large Toaster Ovens that might be able to bake it and help cure it faster.
Old Jun 17, 2021 | 01:24 PM
Hawkeye56's Avatar
Hawkeye56
I believe that I will check around for a old junk grill to use and then dump it
Old Jun 17, 2021 | 01:31 PM
drcook's Avatar
drcook
Here is a small one that you could keep for future work, Or something similar.
https://www.lowes.com/pd/Mr-Bar-B-Q-...E&gclsrc=aw.ds
Don't forget a thermometer
Or check Facebook marketplace or craigslist and get a cheap stove to put in the garage. You can always make coffee on it while working out there.
Old Jun 17, 2021 | 01:47 PM
Hawkeye56's Avatar
Hawkeye56
That is also a option
Old Jun 17, 2021 | 02:21 PM
Hawkeye56's Avatar
Hawkeye56
Old Jun 17, 2021 | 03:10 PM
vette196's Avatar
vette196
I thought the ad posted mentioned the brake heat will cure them.
To VHT High Temp Caliper paint
