emissions control
Old Jun 28, 2021 | 12:50 PM
RDMarine's Avatar
RDMarine
5th Gear
Default emissions control
I just bought a 1984 vette that someone has removed the emissions controls off of the engine. It searches for the correct idle speed all the time. It will idle so slow it dies at times but will start right back up. It will idle between 300 rpm to 1200 rpm and idles rough. I changed the Idel speed controls which did help some but it still searches . What can I do to get a smooth and steady idle. They removed the AIR pump, blocked off the EGR and removed the switches. if anyone has any ideas I would be greatfull for the in formation.
Old Jun 28, 2021 | 09:18 PM
aklim's Avatar
aklim
You may have to adjust the min idle rate. I don't know much about an 84. I don't believe the blocked off EGR and AIR pump would affect it that much.
Old Jun 29, 2021 | 10:03 AM
ctmccloskey's Avatar
ctmccloskey
When you get a chance you might want to be sure that your EGR and AIR systems have been deleted in the code. There are folks out there who have removed the EGR but not in the software. All would be healthier for the engine without the EGR functions.
There are plenty of folks here with the 1984 Corvettes and they know how to make them work really well!
Old Jun 29, 2021 | 10:43 AM
RDMarine's Avatar
RDMarine
5th Gear
How do you delete them from the code. I'm not sure how to access the code.
Old Jun 29, 2021 | 10:47 AM
aklim's Avatar
aklim
Know anyone who writes codes for an 84?
Old Jun 29, 2021 | 03:32 PM
Phobos84's Avatar
Phobos84
I'm not aware of anyone who wrote PROMS for the 84. Most of us back in the day swapped in 7747 ecu's out of throttle body trucks. Everyone and there brother wrote chips for that thing. I know I removed my air pump and egr but I don't remember it ever throwing a code or having any issues with idle. But that was 20 years ago so maybe I just don't remember.
Old Jul 19, 2021 | 08:38 PM
RDMarine's Avatar
RDMarine
5th Gear
Default C4 Random Misfire
I.have gotten most things figured out so far but now i am down to the car having a random misfire. Where is the best place to start to cure this problem.
Old Jul 20, 2021 | 10:54 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Misfire
Random misfire on these cars can come from many places.
1. Remove the spark plugs and see that they are all the same. Lightly tan.
check the gap and reinstall.
2. next pull each plug wire and check the resistance of each wire.
check that each does not have more than 1200 ohms.
3. Next pull the pink wire off the distributor cap and make sure the wire contacts the blade firmly.
4. Remove dist cap and check the center pin and the rotor . Look at the rotors edge that is farthest from the center, that it’s not burned back. Inspect the cap for cracks, and plug studs for carbon tracking.
5. Unclip all the injectors and measure the resistance, and make sure they are all close.
start there, look around for loose or broken connectors too
Old Jul 21, 2021 | 11:26 AM
RDMarine's Avatar
RDMarine
5th Gear
Thank you for the information I will check these things out.
To emissions control
