Boxing the x brace
Old Jul 4, 2021 | 10:32 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default Boxing the x brace
I have had guys ask me what I meant by boxing the X brace on my car and all I could do is describe it to them and that is still hard to understand sometimes. So, since I had my x brace off for other maintenance I took some pictures of what I did to box the frame. This made the x brace just that much better. I used ordinary mild steel flat stock and I think it was 18 gauge but I don't remember for sure, it is approximately 1/8 inch thick. I hope this helps someone understand what "boxing" is. My car sits low so just ignore the "battle scars" you see. Illinois roads contributed most of them.
Old Jul 4, 2021 | 10:49 AM
Phobos84's Avatar
Phobos84
I've never owned a convertible Vette but I've pulled parts off several in the wreaking yard. Every time I saw one of these X braces I always thought welding it in like this would be a good idea. Did it make any noticeable difference in handling? Probably makes it easier to jack up.
Old Jul 4, 2021 | 01:31 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ever considered triangulating the center part to the 4 arms? Bet that would be iciing on the cake
How hard was that to remove? Those really do a good job of stopping cowl shake; can they be mounted on a coupe that would be a nice addition. mine would scrape sometimes too stock height never worried about it
Old Jul 4, 2021 | 10:49 PM
jv9999's Avatar
jv9999
Personally, I don't think boxing it buys you much except added weight.
Old Jul 4, 2021 | 11:00 PM
Midnight 85
I also have the camber brace and I can put a jack under one corner and get 3 wheels off the ground. Yes it handles much better
Old Jul 4, 2021 | 11:02 PM
Midnight 85
No, I never gave that any thought. I'm thinking any more would be over kill. JMO
Old Jul 5, 2021 | 12:57 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Did you put it in a jig when you welded it up?
Old Jul 5, 2021 | 01:06 AM
Midnight 85
No, I never got it hot enough to need a jig. Stitch welded a few at a time, then move to another position and repeat. It took forever but when I bolted it up it had no misaligment of holes.
Old Jul 5, 2021 | 11:27 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sorry, but this is not a measure of....anything. I guess it's more a measure of suspension compliance and travel....but not one of frame stiffness. I can "get 3 wheels off the ground on my stock, no-x-braced C4, too. So.
I agree that it likely added weight w/o much additional strength. The meaningful loads on the x brace are in tension and not so much in bending.
Old Jul 5, 2021 | 11:56 PM
Midnight 85
Is it okay if I leave it on the car guys? Just kidding just kidding all points taken
To Boxing the x brace
