1996 Speedo acts wierd
Old Jul 23, 2021 | 12:56 PM
Furias15x's Avatar
Furias15x
Default 1996 Speedo acts wierd
When sitting still my speedo on my 96 will bounce from 0-20-15-40-0-7 then when I move it acts normal. A while back I had to set the idle with a new IAC and I moved the TPS during this time.
On the 96 its not an adjustable part so i am not sure what to do. I used my scanner to check the 0-WOT and its in the proper ranges.
Is the TPS the problem and how to correct it? The car runs and drives fine.
Old Jul 23, 2021 | 04:05 PM
LTxDave's Avatar
LTxDave
When my speed sensor was going out, it would produce erratic readings. I first noticed it as the speed dependent audio would suddenly blast very loudly. I eventually noticed the speedo really flashing 255 mph when this happened. Most of the time it happened as I was coming to a stop.
Old Jul 23, 2021 | 04:58 PM
rhandle's Avatar
rhandle
Default speed sensor
Which is the correct speed sensor to buy for my GS
To 1996 Speedo acts wierd
