Would this much power kill a D36?
Old Dec 18, 2002 | 02:32 PM
TIMSPEED's Avatar
TIMSPEED
Default Would this much power kill a D36?
If my car was putting out 450rwhp/600ft.-lbs. of torque at the tires...would this KILL my D36? I'm not talking about running drag radials/slicks/cheaters. I'm just talking about running everday 275/40 17's. :cheers:
Old Dec 18, 2002 | 02:45 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default Re: Would this much power kill a D36? (TIMSPEED)
I would bet money that it wouldn't last more than 5,000 miles. I'm running a 100 shot on my LT1, putting down 380 to the rear wheels. I never hit it off the line and not through the shifts. I grenaded my brand new 3.75's (Richmond) after 1 summer.
Others may feel different, but that's my view.
Good luck,
Eric
Old Dec 18, 2002 | 02:50 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Would this much power kill a D36? (HOWSER)
I would have to say :yesnod:
Howser that car is AWESOME looking with the C5 wheels.....Cool! :cheers:
[Modified by ski_dwn_it, 2:50 PM 12/18/2002]
Old Dec 18, 2002 | 02:52 PM
scorp508's Avatar
scorp508
About this much [------------].
Old Dec 18, 2002 | 03:00 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default Re: Would this much power kill a D36? (ski_dwn_it)
:iagree: :D
Old Dec 18, 2002 | 03:37 PM
Zix's Avatar
Zix
Would it break? yes. How long until it broke? Good question, considering you are still going to use 275 street tires, your tires should break loose pretty easily, releaving the stress off the rear-end. However, street tires can still get good grip, and some aggressive launches on your part with that much torque will turn that D36 into chiklets, so it would just be a matter of time. I personlly think it would be a waste of time...why have that much power and need to baby the car because of the rear-end?
Old Dec 18, 2002 | 04:28 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: Would this much power kill a D36? (Zix)
Because it's gonna take all the money to build a motor/tranny to MAKE/HOLD that kinda power. :D The rear end will come later...I don't plan to launch hard on the D36 with that much power. (Well, I actually will..once I have the D44, so if the D36 DOES break, I can R&R immediately.)
Old Dec 18, 2002 | 05:46 PM
Phil-tha-Rush's Avatar
Phil-tha-Rush
then. the answer is NO.
simply driving your car wont destroy the rear.
Its just when you decide you need to "do wheelies" that you will be in trouble. :smash:
Old Dec 18, 2002 | 06:16 PM
MrNuke's Avatar
MrNuke
I'm in the same boat with ya..
Just started installing my Vortech on the vette..
I ran 13.5's with the engine not running as good as it should have (vacuum leak, fouled plugs, timing messed up), so I should be in the VERY low 12's if not high 11's with everything running well..
Rule of thumb is if you or I put slicks or ET streets on the cars, we can kiss our rear end g'bye. ALmost guaranteed.
I'm planning to 'learn' to launch and easy into WOT until I can swap my rear for a D44.. :cheers:
Old Dec 18, 2002 | 06:22 PM
vader86's Avatar
vader86
Default Re: Would this much power kill a D36? (MrNuke)
Strictly driving it around town, and if youre especially easy on takeoff from idle, it might hold out a while.
The first time you gun it though=boom.
Thats too much torque for a D36, remember its torque that kills trannies and rears, not the hp.
Old Dec 18, 2002 | 07:14 PM
smallblock's Avatar
smallblock
Nope......as long as the tires spin the rear won't break.... :)
Old Dec 18, 2002 | 08:26 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Would this much power kill a D36? (smallblock)
Might I suggest you start saving for a th400/Gear Vendors tranny setup? You will most definately want that too. Good luck.
Old Dec 18, 2002 | 09:18 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
:yesnod: :yesnod: :yesnod:
Old Dec 18, 2002 | 09:24 PM
red-y's Avatar
red-y
Default Re: Would this much power kill a D36? (Zora)
I am in trouble also - Someone just said recently:
"Modify it until it breaks and then fix it again"
How many of us have done that? :crazy:
Old Dec 18, 2002 | 09:37 PM
BBA's Avatar
BBA
Default Re: Would this much power kill a D36? (red-y)
Guilty. :yesnod:
I really think you should make the car tougher than it is fast...that means putting a D44 in before hotrodding the motor. It looks good when you blow that punk ricer off the road...but then you look pretty silly when he passes you and your dead car on the side of the road waiting for a trailor to haul it to the shop.
Old Dec 18, 2002 | 09:59 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Put it to you this way, my 36 started going with my stock motor on street tires.
To Would this much power kill a D36?
