84 crossfire engine upgrades
I had a c4 (1995) back a few years but life happened and I had to sell it. I am in better shape now and was able to lock down a 112,000 garage kept 84 with the crossfire(unfortunately but oh well)
i have a 4K budget and am looking to bump up the HP. Everything is currently stock , the motor is tired and smokes some at idle . I do plan on pulling it this winter.
I think the easiest route would be to keep the CFI . I am not familiar with porting but I see this likely needs done ( I’m sure I could find a machine shop)
I am seeking recommendations. As I am pulling out the motor for a refresh should I have it bored ? If so does the computer need updated?
if I keep the stock bore what are your recommendations on heads and cam?
thanks all!
I can't believe a 112k mile motor is burning oil. You sure it's not an intake gasket leak? If it's rings, that was a pretty poorly maintained car....
Watch out for folks giving "advice", who've never owned a CFI car, b/c they don't know WTF they're talking about. Any poster in this thread should clarify that. I'll start; I owned one for 12 years.
thanks for the advice! The CFI is certainly a niche. I have a $4k budget and goals are just to maybe get 280-290 horse? It is not a daily and will drive it 5,000 miles a year or less ( this also helps me avoid the emissions inspection in PA)Planned on pulling the motor to rebuild (pistons/rings/etc) . It could be an intake gasket. I plan on pulling the cfi apart and doing a rebuild kit as well.
If you were to do that vortec roller as it sits and install it with a ported intake I'd figure you'd be pretty darned happy with the results. And the fueling could mostly be compensated by the pressure. Those vortec cams are close enough to stock specs that it should be fine. But with the better heads and intake porting you'd be in a good place imo.
ok so port my cfi intake and bolt on vortec heads and insert vortec cam and call it a day?
We did a CFI intake on a Vortec long block in Jim's (CFI-EFI)'s car years ago. It requires new intake bolt holes, and double stacking intake gaskets to get the right intake runner "height"....it's worked great.
There is a gentleman in my town with another 84 thats almost exactly the same as mine but I never see it when I'm driving the car. I always wonder if he's on here or not so I always ask where everyone is from lol.
My experience is to include my own current 82 and the 84. Which also includes the 82/83 camaro, firbird and trans am. I would also vote on the heads may be at issue with the seals going bad, but it may not be the only thing, who knows until you take a closer look. Since you are in PA I would HIGHLY suggest looking into Dynamic EFI there in Phoenixville, PA. Get the EBL Flash II. Last edited by Buccaneer; Jul 26, 2021 at 10:51 PM.
How did it all work? Damn well. Jim (CFI-EFI) lost some cam, going from the stock CFI long block and it's flat tappet cam, to the truck block and it's VERY lame roller cam, but gained head, of course. The "finished product" was as follows:
*STOCK, L31 Vortec long block
*Heavily ported, stock CFI intake.
*free CAI mod
*2" dual exhaust, no cats
*Stock ECM and chip (tune)
*FPR "modded" into an adjustable FPR...I think he was running 13-14 PSI?
*212 RWHP/270 RWTQ at 4200 and 3200 RPM. Car ran 14.10's at 4500' elevation @~95-96 mph, IIRC. Not like today's cars, but damn good for what it was, and the $ that was put into it.
thanks all!
Summit Racing SUM-162109 Summit Racing® 62cc Aluminum Cylinder Heads for Small Chevy | Summit Racing
