No way Jose’ !
Old Jul 27, 2021 | 08:11 PM
Gunney's Avatar
Gunney
Default No way Jose’ !
Good grief! Finally get around to try to replace the back up light switch on my 90 ZF transmission. I’ve been reading the posts on here for months, yes it’s a little difficult but it can be done…..not by me apparently.
The car is on the lift, I remove the “X” brace (it’s a convertible), back out the bolts holding the slave cylinder, as we need room to get in there.
There is nowhere for the slave to go….the hydraulic line is on the top, with the bleed nipple…. It’s jammed up next to the tunnel.
Arrrgghhh! How are you doing this? I must be missing a trick?
Angry and anxious…..
Old Jul 28, 2021 | 08:03 AM
Deepa's Avatar
Deepa
The slave is held on by two nuts. It seems the whole stud backed out on you. The studs should have a reverse torx head on them. You need go break the nut free from the stud, tighten the stud down, and then remove the nuts / slave.
I know those two studs very well. They broke the bottom of my windshield when I was reinstalling my motor / bell housing.
Old Jul 28, 2021 | 10:54 AM
Gunney's Avatar
Gunney
Thanks! I just took a look and I see what your talking about. So, I don’t try to take those bolts out? Just screw them into the case to get them out of the way?
thanks
Old Jul 28, 2021 | 11:52 AM
ajp01's Avatar
ajp01
No, they won't go in all the way. They are studs, not bolts.
When you take the nuts that hold the slave cylinder off, then those studs are able to be unscrewed out of the bellhousing. Use an E7 reverse Torx socket, found at your local auto parts store (they are cheap and individually available usually). Use that E7 socket to get both those studs out, then your slave cylinder will move further downward out of the way. You can reach the backup light switch with an open-end wrench but it's hard. It's easier if you get one of those crows-feet sockets designed for oxygen sensors. At least it was for me.
Old Jul 28, 2021 | 12:27 PM
Deepa's Avatar
Deepa
I never had to remove the studs to remove the slave on my 91. Only difference is that I have long tubes and true duals so that may have made my access a little better.
don’t be afraid to loosen the slave and manually push the slave housing to the bell housing. This will compress the piston and give you more wiggle room to sneak the slave out of the way.
Old Jul 28, 2021 | 05:41 PM
Gunney's Avatar
Gunney
Thanks guys, I’ll try this again if a few days, I’ll report back how it went
Old Jul 28, 2021 | 08:30 PM
bud40oz's Avatar
bud40oz
invereted torx i bought a set at a harbour freight for like 12 bucks, think it was the size 6.. c 6 or s 6.
Old Aug 30, 2021 | 08:12 PM
Gunney's Avatar
Gunney
Success! A friend helped, now I have backup lights!
appreciate everyone’s input!
To No way Jose’ !
