Engine miss
Old Jul 28, 2021 | 08:04 AM
Summies's Avatar
Summies
Cruising
Default Engine miss
At speeds between 45-55 MPH, my '92corvette misses. I had a mechanic​​​​​ look at it, clean the in injectors.Also ran a can of sea foam through the tank.
Any suggestions?
Old Jul 28, 2021 | 04:09 PM
Mrvettenick's Avatar
Mrvettenick
At that speed, the lock up converter is engaged. Is it a misfire, or the converter dropping in and out? Get a scan tool to see if the command from the ecm is consistent,
