Electrical question
Old Jul 30, 2021 | 04:49 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Default Electrical question
I was tinkering around the rear side of the motor today, just casually inspecting things and for some dumb reason I decided to pull the connector off the oil pressure switch. I guess just to see if there were any traces of any oil sitting in there. Which there wasn't.
Anyway, the clip which secures the connector to the switch snapped off. So now it's kind of just sitting on the end of it.
The oil pressure switch threads into the oil pressure gauge fitting in a way that renders the switch sitting vertical rather than horizontal. The oil pressure sensor being the one that ends up horizontal after it threads into the same fitting.
So, since the oil pressure switch sits vertical and the connector sits on top of it, it seems like vibration would be the only thing that might cause the connector to fall off. As I said, the conector isn't really tight. It jiggles pretty loosely. But it's sitting on top of the switch. So gravity is kind of on my side here. Seems like it sould be okay until I get around to feeling like swapping out the pigtail.
I need to find that pigtail in the mean time.
My question is, if the connector does come off of the switch, nothing will happen, right? It's just a backup to the fuel pump relay? It doesn't do anything else but that?
I was thinking about trying to fish a long zip tie arount the end of the connector and the fitting just to keep the connection secure for the time being, but there's just no room.
Thanks!
Old Jul 30, 2021 | 07:12 PM
ajp01's Avatar
ajp01
I know what you mean. When I went through my motor these past months pretty much every WeatherPak connector locking tang snapped off. I ended up replacing a whole bunch of them as they are easily available through repairconnector.com and eficonnection.com. Rather than splice in a new pigtail, I just used the tool that pushes out the metal pins from the broken connector and then insert / re-lock the original pins into a new connector body.
https://www.eficonnection.com/home/c...-kits?start=25
I believe you are correct, the oil pump pressure sensor is a backup for the FP relay. There was an article I read years ago that said that the sensor was checked during the start cycle for pressure, but that article was wrong as other forum members pointed out to me. And I think you're right, gravity and the natural bent-wire pressure that the pigtail normally has will keep that connector seated until you can fix it.
Old Jul 31, 2021 | 01:15 PM
Natty C's Avatar
Natty C
Thanks for that link. Looks like they carry a few oddball connectors. I've prety much replaced the weatherpacks with new pigtails.
Just those oddball conectors that I need to replace. They'l all start snapping off after thirty years, no doubt.
Here, I'll trade you a good bulb link for the connector link. Ha.
I found this link when I was looking for natural amber (NA) bulbs versus the painted amber ones the chain stores pawn off...
https://www.bulbtown.com/
Old Jul 31, 2021 | 01:49 PM
ctmccloskey's Avatar
ctmccloskey
Thank You ajp01 and Natty C
That is a great resource you have both mentioned above! I was impressed to find out they have stores like this.
Eastwood company sells kits to make your own weather-tight connections. I have one kit that has from 1 wire up to 10 wires and has both ends available to build your connector. It is great when you are building something but has been helpful when I have a broken connector. I have the US standard and the European standard weather-tight connectors to make as you need them.
Now that I know about the EFIConnection.com I will use them for sure. Thanks for enlightening us! Thank you Natty C as II forgot to say thanks about the BulbTown site as well!
I love this Forum, you learn something new every time you visit!
To Electrical question
